loudest plane without afterburners
Hi all whats the loudest plane without afterburners?
Re: loudist plane without afterburners
I know it's not the loudest but many years ago I was at Brize and a visiting Jet Provost T3 took off and it was very loud, even compared to the VC10's and all the other visitors that day! Another loud one was definately the Vulcan!
A Dominie is pretty loud when your near it. Especially 4 parking up at once
Personally, I thought the Vulcan at Bruntingthorpe during Cold War Jet in May 08 was darn loud!! That or the Tu-95!!
USAF T-39's Departing RAF Northolt!!!!, the whole place vibrated with the noise
Help save Denham Aerodrome and surrounding area, NO TO HS2http://epetitions.direct.gov.uk/petitions/353
Nimrod is another noise bleeder.
Macc
Macc
B-52D doing a max wait take-off with water injecshun winns it evry time... The dinn is (was...) indescribabubble, espeshly if you hapened to be lirking at the otha end of the runway with the Buff coming strate four you... It was paineful... And four propella-engined aircraft, the C-119 used to make a fare old raket...
I am not a loony... I used to be, but I think I am better now...
The most obvious choice I would say has to be the Vulcan. However, there have been many more contenders in the past, both Military and Civilian.
i.e. Early Boeing 707s, VC10s, the other V Bombers (Valiant and Victor) and among the twin and single engined variety; All marks of Javelin up to the mark 7 (the 8s and 9s had afterburner!) and the Sea Vixen. Oh and the Mark 9 Canberra and any Hunters from mark 6 upwards. All guaranteed to turn heads with their heavy use of throttle!
I have danced the skies on laughter-silvered wings!
I would have to say that the loudest I've heard is the Vulcan in a power climb. That was LOUD!
I'm talking back in the old days though when the RAF used to throw it around the sky.
This was apparently one of the loudest, although I doubt many on here would have witnessed a flight Enter the Pogo!
http://en.wikipedia.org/wiki/Convair_XFY
Then again just for ear piercing annoyance the Marbore engines of a Magister or Paris are horrible or a hovering Harrier just above your head
Always thought a Trident 3 on take off was pretty loud.
- flygirl
- Location: In nubibus & Royal Military Academy Sandhurst
Dunk wrote:A fully loaded VC-10 certainly wakes up most of Oxfordshire when it goes off! Crackles for miles.
Gets my vote.
We're not lost. We're locationally challenged. http://planemadanna.blogspot.com/
VC-10 or Harrier!
As I've inferred before, the loudness depends on how close you are to the nozzle. If your head is inserted into the jet orifice, most jets are equally loud. If however you are located in the next county, it depends on the wind direction and the resonant frequency of the engine in question. I hope this helps.
MikeH wrote:As I've inferred before, the loudness depends on how close you are to the nozzle. If your head is inserted into the jet orifice, most jets are equally loud. If however you are located in the next county, it depends on the wind direction and the resonant frequency of the engine in question. I hope this helps.
Pardon?
Epic Formacion wrote:Pardon?
I SAID....!
BTW shouldn' it be "Epic Formação?"
The loudest aircraft in the world was the XF-84H 'Thunderscreech'
"On the ground, they were reportedly audible 25 miles away.
Sound pressure produced by the aircraft’s turboprop engine caused nausea and headaches among ground crews"
http://en.wikipedia.org/wiki/XF-84H_Thunderscreech
And apparantly, this is what is sounded like:
http://aviationtrivia.info/documents/xf84_h.wav
- acw6535 the 2nd
I remember being at the end of the runway at Mildenhall back in the 70s,and a KC135 (before re-enginning) took
off...the noise was extremely loud,with a deep rumble sensation in my chest.
Never experienced anything remotely close since then.
Lightnings were the next loudest.I recall being at a show in the 70s,and several took off at the same time
(but that`s with burners,so I guess it doesn`t count)
I also remember the Dan Air 727s doing a full power take off(again,back in the 70s)...you could hear them for 10 minutes after they`d flown overhead
Blue Moon...you saw me standing alone...
www.flickr.com/photos/allenthepostman/
Macc wrote:Nimrod is another noise bleeder.
Macc
Yep, I'd go along with that.
Especially when they used to do ground runs at RAF St Mawgan (early 1980s) of an evening and you could hear them in Newquay.
Personally I would have gone for a BAC1-11, a Trident or a VC10, and maybe the old 707 or DC8 with their old powerplants!
http://www.flickr.com/photos/65589468@N04/
View on this site are my views and not those of any organisation!
The Sort SC 1 in the hover was a really loud and painful little beastie. While I recall the early Vulcan at Farborough as being one big very noisy vibrator
Tupolev Tu-104, first aircraft ever to be banned from Heathrow, (in the 1960s) for excessive noise, from the point of view of the average person. However, as previously stated the XF-84H is officially the loudest single engined aircraft ever, although I suspect the XB-70 Valkyrie might run it pretty close on ultimate noise, as I believe it had the greatest installed thrust ever.
nothing is confirmed at a show until its u/c hits the tarmac or it is running in for its display.....
I'm with Dunk on this one. Stand at the end of active runway '26 at Brize and watch a heavily loaded VC10 takeoff using water injection is a "whole body" experience
I'll go with with the Trident on take off on this! On the ground the noisiest I've worked on is the ATP and the Emb 135/145 APU isn't quiet either
