Hi has anybody on here tried this?
FSPS – FSX Booster Version 1.3
•Ultimate smoothness.
•Extra Frames from 30% and more
•Free updates for ever
•PC information’s for tweak calculation
•Blurries Elimination
•High Definition Textures
•Extra Lod Radius
•Fibers speed increase
•Vertical screen synchronization
•Shaders rebuild
•Hyper Threads CPU’s compatibility
Now there is no reason to try to find FSX tweaks over the internet. Each person's computer is different, so what works for one person often won't work for you.
FSPS - FSX Booster has been designed keeping in mind the thousands of possible hardware configurations. The special software analyzes your computer hardware in depth (CPU, GPU, memory, hard disc speed and etc.) and sets a number of documented and undocumented tweaks to the correct values that is optimal for your PC.
No technical knowledge is needed. Just execute FSPS - FSX Booster, then FSX and enjoy it with the maximum frames and smoothness you can get from your PC
Requirements: FSX SP2 or Accelerator
.NET Framework 3.5 or higher must be installed
OS: Win XP, Vista, 7 32 or 64 bit
Internet connection
*Note: One licence per PC
Was just wondering if it was any good.
FSPS - FSX Booster
FSPS - FSX Booster
Spartans,Prepare for glory.
Re: FSPS - FSX Booster
Hadn't heard of it before but there's a free demo here
