In 1/32nd scale.. funnly scratch built, will include resin engines as the only bought item... big learning curve but should be fun.
Scratch built 1/32nd AJ-1 Savage by Radleigh Bushell, on Flickr
Scratch built AJ-1 Savage (update)
6D | 7D | 60D
Re: Scratch built AJ-1 Savage
Wow...that looks like some serious building ahead
And something I will look forward to seeing completed.
Tim
Tim
- Jamesv9820
I do take my hat off to you Radleigh - look forward to seeing this one progress
Thanks guys, progress has been a bit slow due to other commitments but I've now finally got a rough shape I can work with. Next step is to cover this is resin, then car filler so it can be sanded to the correct profile. I've cut up some plastic card profile templates to check along the fuselage so both sides are the same..
Just the one photo as there isn't much to show at this stage, and a Zippo for size comparison.
Thanks for checking in..
6D | 7D | 60D
Re: Scratch built AJ-1 Savage (update)
Geez this looks like it'll be a pretty big build judging by the picture with the Zippo. Looking forward to more updates as you get them.
Fumbles wrote:Geez this looks like it'll be a pretty big build judging by the picture with the Zippo. Looking forward to more updates as you get them.
23.6" long, 26.6" wide.. so a good chunk! Thanks Fumbles.
6D | 7D | 60D
