When I built models as a kid it seemed the only glue around was a tube of poly cement and from memory it got everywhere!
So the question is what type and brand do the modeller's use nowadays?
Just a quick question: Glue?
Re: Just a quick question: Glue?
Still use the good old fashioned poly cement myself.... Revell and humbrol brands are the tubes I currently have...
I haven't used a tube in long time.
I use:-
Revell Contacta until the tube clogs up - major pain.
Humbrol liquid poly for most jobs
Superglue for those tiny bits and metal parts
White PVA glue for clear parts
I use:-
Many thanks for the replies chaps, had read about the use of super glue but a little unsure on what bits you use it on?
Take it PVA is pretty much the same as wood glue possibly?
Thanks for the info, maybe I'll make a start on the Pit Road Vulcan over the weekend!
DerekF wrote:I haven't used a tube in long time.
I use:-
Wipe the tube after use, or, if it jams up use a piece of fuse wire.
Tamiya liquid stuff decanted into a Mr Cement bottle (better brush). I went to liquid glue at the start of the year and personally found it much easier and cleaner to work with.
facebook.com/shgpmedia
instagram.com/shgphotography86/
Youtube - SHGP Media
- Jamesv9820
Tamiya Extra thin is definitely the way to go. Tamiya Cement is pretty good but I found it very similar to Revell Contacta.
