V.J Day flypast
V.J Day flypast
Does anyone have the route of the flypast for V.J day this saturday?
Re: V.J Day flypast
Didn't even know it was happening! Does anyone have any idea what aircraft are participating.
2016 Shows
Duxford Spring
Weston
Cosford
Yeovilton
RIAT
Bournemouth
Jersey
Duxford Spring
Weston
Cosford
Yeovilton
RIAT
Bournemouth
Jersey
Re: V.J Day flypast
BrizeWatcher wrote:Didn't even know it was happening! Does anyone have any idea what aircraft are participating.
BBMF, Swordfish and a Typhoon I think
Re: V.J Day flypast
Benviation wrote:BrizeWatcher wrote:Didn't even know it was happening! Does anyone have any idea what aircraft are participating.
2016 Shows
Duxford Spring
Weston
Cosford
Yeovilton
RIAT
Bournemouth
Jersey
Duxford Spring
Weston
Cosford
Yeovilton
RIAT
Bournemouth
Jersey
Re: V.J Day flypast
Below is the NOTAM, remember to ADD 1 hour
Start date/time: 15/08/2015 12:40 UTC
End date/time: 15/08/2015 13:15 UTC
Activity period: null
Lower height limit: 000
Upper height limit: 025
FLYPAST ROUTING FOR ANNIVERSARY FLYPAST. ROUTING AS FOLLOWS:
513300N 0001833E (HOLD S THURROCK) 1240
513104N 0000018W (S THREE MILLS VRP) 1257
513017N 0000742W (HORSE GUARDS PARADE) 1315
ALL AIRCRAFT HAVE SEPARATE ROUTINGS OUTBOUND FROM THE LONDON/CITY
CTR. OUTSIDE OF CONTROLLED AIRSPACE, OTHER AIRSPACE USERS ARE
REQUESTED TO AVOID THE ROUTE 3NM EITHER SIDE OF TRACK DURING THE
STATED TIMES. 15-08-0045/AS1
Gary
Re: V.J Day flypast
Awesome.....
Re: V.J Day flypast
That'll be 'BBMF & Typhoon' , then , 'cos the Swordfish'll probably go tech.
Re: V.J Day flypast
Don't think the RNHF/FNHT had a problem with her since returned to the air but no doubt you just cursed it http://www.fnht.co.uk/swordfish-to-lead ... ondon.html
James
James
RIP Red 4, Flight Lieutenant Jon Egging 1978 - 2011
RIP Red 5, Flight Lieutenant Sean Cunningham
- craig.mason
Re: V.J Day flypast
Its on tv a 2pm the bbc will more than likely cockup the filming of the flypast as they usually do
Canon 550D
EF-S 18-55mm F3.5-5.6 IS II Lens
EF-S 55-250mm f/4-5.6 IS II
EF 75-300mm f/4.0-5.6 III USM
Re: V.J Day flypast
craig.mason wrote:Its on tv a 2pm the bbc will more than likely cockup the filming of the flypast as they usually do
And here comes a Boeing Stearman
- craig.mason
Re: V.J Day flypast
I thought that todays flypast was very poor 1 hurricane & 1dakota +eurofighter sworfish unable to attend you would think that with all the warbirds that fought against the japanese based in the uk at duxford they could have done a much better flypast today
Canon 550D
Re: V.J Day flypast
Brevet Cable wrote:That'll be 'BBMF & Typhoon' , then , 'cos the Swordfish'll probably go tech.
Yep you cursed it
James
