Duxford September (non-DSLR m43) - Updated
What a cracking good day at Duxford on Sunday! I had no gripes about which planes were (or were not) there, whether or not it matched PR materials etc... because I bought my ticket long before I knew anything about the attendees anyway! :-D All I saw on the day, was a cracking good lineup! :-D Pure luck that I chose a Sunday ticket... fabulous weather... perhaps too good for photography - such harsh light, and atmospheric heat distortion ruined many nice shots... O_o
I loved seeing the Bearcat and Fury up close on the flightline walk - they are such beasts, huge brutish piston power!
There were several types I hadn't seen before...
so many Spitfires... the Red Arrows of course...
Great War Display Team re-enactment... etc etc.
Great day out!
1. Spitfire IX
2. Chipmunk
3. Bearcat and Fury
4. Junkers CL1
5. Fokker Triplane and BE2c
6. Buchon
7. Buchons
8. Gladiator
9. Yak-3
10. Nimrod
11. Harvard
12. Lancaster
13. Corsair
14. Hurricane
15. Mig 15
16. Vampires and Mig 15
17. Mig 15
18. Vampires
19. Catalina
20. Spitfire XVI
21. Spitfires
22. Sally B
23. Sally B chasing a Jumbo off her turf
24. Spitfires
25. Spitfire Vb
26. Mandatory Red Arrows crossover shot
27. Red Arrows
All taken with my little Panasonic GX80 micro four thirds camera, and Panasonic Leica 100-400 lens (200-800mm equivalent). Red dot sight fitted as usual:
I've abandoned posting 1600px images and gone back to 1200px, since I find it annoying that they don't fit in my browser window at full size, they take up too much space on my web site, and they can slow down page loading too much... :-/
Well, hope you saw something you liked! More to come from the ground displays...
EDIT: MORE ADDED BELOW
Great day out!
1. Spitfire IX
2. Chipmunk
3. Bearcat and Fury
4. Junkers CL1
6. Buchon
7. Buchons
8. Gladiator
9. Yak-3
10. Nimrod
11. Harvard
12. Lancaster
13. Corsair
14. Hurricane
15. Mig 15
17. Mig 15
18. Vampires
19. Catalina
20. Spitfire XVI
21. Spitfires
22. Sally B
24. Spitfires
25. Spitfire Vb
27. Red Arrows
Goodbye 600D... Hello FZ150!
- LN Strike Eagle
Re: Duxford September (non-DSLR m43)
You're not obliged to post at 1600px. Do what suits you. I'm posting at 1500px personally, as it better fits on my screen res, and the file sizes are much the same as they were at 1200px - I aim for around 400-500KB.
I look forward to your static/flightline photos.
aknott68 wrote:There are some great photos there I can only look in admiration as to how you get the shots with the complete propeller circles -I understand the concept of using slow shutter speds to get that impact but I just don't know how you achieve that stillness with a large lens, any points would be appreciated.
I can tell you how I do it, but bear in mind it's not necessarly the "best" way, and may not work at all for you personally...!
I use "shutter priority"... shutter speed 1/60th or less depending on the type of plane, and how many propeller blades it has (more blades allows you to use faster shutter speeds). The full-disc prop blur photos above all used 1/50th or 1/40th. As you already realise, it's devilishly hard to get a clean shot of a moving plane at such slow shutter speeds!
It starts with your panning technique. I use this method (devised aeons ago, and not by me): stand legs apart for stability... face where the plane will "pass" you... lock your arms, head, camera, torso together and turn them as a single unit, from the waist... either hold your breath, or breath out slowly... turn towards the plane and pan smoothly with it... shoot while you are panning, as the plane passes in front of you, and follow through afterwards (keep panning smoothly even after you stopped shooting).
I normally shoot bursts of 2-3 photos for planes in flight, but for full-disc prop blur, I'll use much longer bursts eg. 5-6 shots, and probably multiple bursts in a row as well - because the probability is, a very high percentage will be duds. I don't really expect more than one or two "keepers" in each pass.
But you can also shoot when planes are revving their engines but not actually moving. Then with good image stabilisation, it becomes relatively easy to get a clean shot. You could also use a monopod/tripod when they're moving if you've got a clear view of the section of runway where where they take off/land (I wouldn't try to pan over too wide an area with a monopod/tripod - trip/fall/collision hazard)
Take-offs allow faster shutter speeds, because the planes will use higher revs... and faster shuttter speeds means more keepers. (planes may use lower revs during display passes, and may be practically idling when coming in to land).
I find the best results are when the sun is shining "on" the propellers (sun is not behind them). It makes for good contrast between the propeller/tips and the background.
And I also find my red dot sight helps with accurate panning. I use it instead of the camera viewfinder, so I can watch the show with both eyes and a full field of view, while still taking photos. I hold the camera strap taut against the back of my neck to make a "tension tripod" with my two arms. Then I put the red dot on a spot on the plane and keep it there by panning - to me, it's rather like pointing your finger. I use quick glances at the rear screen to check zooming when needed. I find that much easier than looking through a viewfinder, and trying to keeping the plane from moving around inside the frame. But perhaps that's just me.
And of course, lots of practice will help! It may help that I spent half my life with film SLR's back in the days when there was no such thing as image stabilisation, and nothing on your camera had a name prefixed by "auto", "e-" or "i-" :-D Without the crutch of IS, you simply learned to hold a camera very steady! :-D On my compact cameras, I routinely turn off IS for airshows anyway, because they either don't have a panning mode, or the IS still gets fooled by panning anyway and I get better results without it...
Anyway, I hope that gives you a few pointers. Experiment and see what works for you! Take some some nice "regular" shots of a plane, before trying some shots with slow shutter speed panning. Then at least you'll still have some nice photos even if the slow shutter shots don't work out!
LN Strike Eagle wrote:You're not obliged to post at 1600px. Do what suits you. I'm posting at 1500px personally, as it better fits on my screen res, and the file sizes are much the same as they were at 1200px - I aim for around 400-500KB.
Thanks, yes. I do like that 1600px shows better detail, and I persevered to see if I would simply get used to it... but nah, I think 1200px is more preferable and "practical" for me :-D
Why haven't I seen any GWDT/Pyrotechnics shots when several people have mentioned it?
Fine views and thanks for taking the time to explain your methods for the wonderful prop blur and panning shots ,Hatstand.
Thanks qwerty!
LOL :-D OK, just for you:
sdad wrote:Why haven't I seen any GWDT/Pyrotechnics shots when several people have mentioned it? :-)
That's a bonfire!
- tankbuster
nice set especially number one.
Trevor C
recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
aknott68 wrote:Sorry I meant to ask about red dot sight not something ive heard of before is this something suitable for nikon dslr do you know?
It's like a miniature heads-up display, that shows a targeting reticle (the red dot). As you look through it, the red dot will magically always appear over the place your lens is pointing at. This lets you instantly point your camera at a subject and track it, even with a long zoom, even without achieving focus... and without having to zoom out first to find the subject, then zoom back in to take the photo.
It can be useful on any camera, including a DSLR. But it's especially good for birds/insects in flight which move fast and unpredictably, and for older compacts that have rubbish EVF's. I mainly use it these days because it lets me watch airshows with both eyes and full field of view, while still taking photos - instead of spending half my time peering through a restrictive viewfinder....
Here's a few photos from the ground displays...
28. Mustang chaps
29. Spitfire chaps
30. Seafire
31. Spitfire
32. Mig 15
33. Fury
34. Bearcat
35. Spitfire
36. Corsair
Panasonic GX80 micro four thirds camera again, with Panasonic 12-60 lens (24-120mm equivalent)
28. Mustang chaps
29. Spitfire chaps
30. Seafire
31. Spitfire
32. Mig 15
33. Fury
34. Bearcat
35. Spitfire
36. Corsair
Re: Duxford September (non-DSLR m43) - Updated
Thats a cracking set of shots Love my m43 cameras
Glad you had a good day and some cracking shots. We enjoyed the Sunday after Sat weather.
Hi res copies of the GWDT would be appreciated.
Interesting comment re GWDT and pyros. It must be a challenge with timing and framing to get aircraft and pyros in the same shot. We have been sent a few crackers with aircraft surrounded by Archie but we are thinking of running a completion based on that shot to get some more.
You've nailed it again
I was there on Friday to video in 4K, but the gamble didn't really pay off, not too much going on - but I learned a lot, as always.
Just need to stop repeating silly mistakes now - like remembering to press that little button again when I've got the sequence...
Anything less than 900mm is wide angle
Your opening shot is stunning
Thanks for the panning technique detail you provided...super!
Many thanks for all the comments above, everyone!
You can buy red dot sights online from places like Amazon, or from airgun shops etc. Sometimes they are called "tactical gunsights" or somesuch. I favour ones like this which are available under many different brand names (and prices!). The key features:
-Big mirror
-Thin frame around the mirror
-"Open" design (not "tube")
-Selectable reticles (I favour a dot in a circle)
-Multiple brightness levels
-Red/green colour selection
Then to mount the RDS in your camera's hotshoe, I use Photosolve's mounting
aknott68 wrote:Thanks for the information hatstand could you give the details as to where u got it from
-Big mirror
