I opened a new tube of white stuff about a week ago. This evening I have attempted to squeeze a bit out onto a tile for use and all that comes out is a thick, nearly clear gloop. It's as if the medium and the filler material have separated.
Has anybody ever had the same problem?
White stuff filler problem
Re: White stuff filler problem
iainpeden wrote:I opened a new tube of white stuff about a week ago. This evening I have attempted to squeeze a bit out onto a tile for use and all that comes out is a thick, nearly clear gloop. It's as if the medium and the filler material have separated.
Yes, with other brands of filler. Once the gloop is gone it should behave naturally, but I tend to agree it has split in the tube - maybe old stock....
It rather puts you off applying it directly to the model, as well.
