Airfix Club Spitfire MkXVI FINISHED
A forum for UKAR Group Builds
Tug 747
UKAR Moderators
Post by Tug 747 »
This is my first contribution to the Airfix group build I am a bit late looking at those who have already started.
Doug
Re: Airfix Club Spitfire MkXVI
I was toying with the idea of getting this as I actually missed it as I joined just after.
Looking forward to this mate.
DerekF
Post by DerekF »
So which one? Black and gold or silver and red?
If you are doing the black one, be aware of Airfix's see-through decals.
Tug 747
UKAR Moderators
Post by Tug 747 »
Derek i will be doing it as TD248 as i have shots if this aircraft taken at Duxford.
DerekF
Post by DerekF »
I did the black one. I was planning on doing TD248 using a ICM MkXVI with the decals left over.
Tug 747
UKAR Moderators
Re: Airfix Club Spitfire MkXVI Update 15/11/12
Post by Tug 747 »
Looks like i have enough bits here for two machines all that is missing is the bottom wing section and the fuselage some of the parts seem totally irrelevant to the Mk XVI.
Well this is where i am at the moment
Well the dry fit has revealed some nasty gaps that will need filling
Well i shall update in a few days when i have mastered my filling and sanding techniques.
those gaps are awful mate. :hide:
Good luck! :smile:
Cimmerian
Post by Cimmerian »
Bulk delivery of filler for Mr Tug 747.
Good luck. Hope it goes better than the disasters I'm trying to deal with. :smile:
Regards, Ken
ArabJazzie
Post by ArabJazzie »
I have this in the stash but looking at this has placed a few more kits in front of it in the build pile!
Good luck,
Tug 747
UKAR Moderators
Re: Airfix Club Spitfire MkXVI Update 21/11/12
Post by Tug 747 »
Well i have completed the filling and sanding down and I must point out that I am not very good at these but I have made an effort.
Filled and sanded and primed
Silver applied and awaiting decals which I shall endeavour to do today and tomorrow
Thanks for looking
jaguar
Post by jaguar »
Hi Doug,
Very nice kit and well done :clap: :clap: :clap: looking forward to seeing the finished product.
Paul.
CPC Aviation Photography
Canon 500D
Canon 600D
Canon 18-55mm
Canon 28-135mm
Canon 75-300mm
Canon EF 100-400MM f/4.5-5.6L IS USM
Great progress mate. :clap:
Can I suggest that another coat of metal, thinned but not too watery, would get rid of some of the brush marks. :smile:
Tug 747
UKAR Moderators
Post by Tug 747 »
Alan I had already put the decals on but they broke apart and blistered for some reason so i have stripped of all the decals and and rubbed the paint work down and i will attempt to spray the thing in a few days. And then I will endeavour to paint the red lines on and reapply the decals.
canon55k
Post by canon55k »
Hi Doug,
What the hell happened to that , why have you used a brush when you have that cracking spray gun.
Looks like your rushing it. Bin it or start again.
Ian
Canon 1DX,
Canon 5Dmk111
Canon EOS 1NRSx2
Canon EF70-200F2.8
Canon EF24 -105LF4
Canon EFIS 100-400 mk11
Canon 500mmf4
canon55k
Post by canon55k »
Hi Doug,
Have attached a scan of the real thing if it helps
Regards
Ian
Canon 1DX,
Canon 5Dmk111
Canon EOS 1NRSx2
Canon EF70-200F2.8
Canon EF24 -105LF4
Canon 500mmf4
jaguar
Post by jaguar »
Doug,
Spraying it and spraying the red lines will be your best option.
Paul.
Canon 500D
Canon 600D
Canon 18-55mm
Canon 28-135mm
Canon 75-300mm
jaguar wrote:Doug,
Paul.
No pressure! :lol:
Fumbles
Post by Fumbles »
Did you get a chance to sand this down and spray it yet? Maybe order a set a new decals from Airfix. Spraying red lines in not the easiest of colours to do.
Tug 747
UKAR Moderators
Re: Airfix Club Spitfire MkXVI FINISHED
Post by Tug 747 »
Well i was going to give up on this and bin it or leave it as a bad job but i cheated a little and jaguar did the spraying for me as i was not in the mood to continue with it.
So thanks to Paul i can now share it with you in all its glory. Any comments regarding the final spraying of the silver and the red lines may well makes his head swell or shrink :lol:
The only thing that i am not happy with is the decals. As you can see they are transparent.
Well that is my contribution even if i did have a little help and it is not all my own work
DerekF
Post by DerekF »
Not too shabby at all.
I made this kit into the black and gold one. Fortunately I had two sets of decals as they were so transparent that some of them disappeared completely.
I've still got the decals and an ICM MkXVI to have a go at.
Tug 747
UKAR Moderators
Post by Tug 747 »
DerekF wrote:Not too shabby at all.
Thanks Derek i went with the silver one as you said in a previous post the decals went see through on the black one .
Well done sir, you've made a nice job of that. :clap: :clap:
ArabJazzie
Nice recovery!
Considering what you have had to deal with along the way, im surprised you had the will to finish it at all!!!
Fumbles
Post by Fumbles »
I'll give you credit... I would have binned it a long time ago. The whole kit took a complete 180. Your builds are getting better and better each time. Even with a little help on the paint.
Tug 747
UKAR Moderators
Post by Tug 747 »
Thanks for all the comment's and wisely words of encouragement along the way.
