Mildenhall 18/10- Herk refueling hose IFE
galaxysi
Post by galaxysi »
lovely day today with loads of movements,mostly c-130's.units include Dyess,Bragg Pope and Wyoming.Also dropping in was a Turkish herk and the special ops boys were out in force as well,with 4 of there aircraft active throughout the day.one of the 67th MC-130P's returned later with one of its refuelling hoses stuck extended.it flew down the runway at 200 feet and then cut the hose,which made for an interesting photo opportunity.also there today were various tankers,the highlight of these being a couple of Tinker tankers.(i have not posted pics of the based stuff,only the IFE aircraft).
wyoming ANG
Dyess
Turkey herky
Tinker tanker
Dyess
Bragg Pope
IFE MC-130P
thanks for looking.
PAPA LAZ
Re: Mildenhall 18/10- Herk refueling hose IFE
Post by PAPA LAZ »
Very nice chap,good to catch up today.See Sunday for more of the same :wink:
Beefy
Post by Beefy »
Nice shots Si :clap: :clap: It was a cracking day for movements and the Sun was out most of the time!
Monty
Post by Monty »
Nice pics, will try and get mine on in a while. Was quite something seeing that Herc cut the hose wasn't it? Me and my brother were the two teenagers who were on the trailer.
:smile:
Canon EOS 50D
Canon 18-55mm IS
Canon 70-300mm IS USM F-4.0/5.6
1094 (Ely) Sqn ATC
SamP
Post by SamP »
great shots! :clap: :rock: :clap: very unique one of the hose being cut :topbombing: . what cut it? or is it a normal procedure???
scotthldr
Post by scotthldr »
The Hose Drum Reels have a cutter built into them for that exact reason. Can't believe the Turks are starting to go Grey on their Herc fleet :sad:
SamP
Post by SamP »
thaks for the info, does that mean it jamed then, cause i would have thought it would be safer & easier to reel it in (god im a noob :sad: )
Monty
Post by Monty »
Spirt Of Kitty Hawk wrote:thaks for the info, does that mean it jamed then, cause i would have thought it would be safer & easier to reel it in (god im a noob :sad: )
Yeah it was jammed, something called up at around 1:30 saying it had an inflight emergency and was dumpuing fuel, then this called up around 3:30ish (i think, wasn't really paying attention to the time). They evacuated the buildings in the vicnity before it came in, but only got one fire truck out. about 10 minutes after everything had been sorted out the other 6 came out, stopped on the other side of the runway and then went back in. :smile:
Canon EOS 50D
Canon 18-55mm IS
1094 (Ely) Sqn ATC
galaxysi
Post by galaxysi »
thanks for the comments.i doubt i'll ever see that happen again.
SamP
Post by SamP »
Thanks for that, must have been a right 'kaffufle' eveactuating the place! - well done again galaxysi :clap: lovely shots of a RARE! accurance
agdickie
Post by agdickie »
Shadow dropping its drogue is quite something :clap: :shock:
Agdickie on Airliners.net
Hey jet pilots! Do a barrell roll!
PAPA LAZ
Post by PAPA LAZ »
galaxysi wrote:thanks for the comments.i doubt i'll ever see that happen again.
You never know Si,we'll be there if it does budd :biggrin: :wink:
DaveI
Post by DaveI »
Just a bit of technical info. The hose is attached to the drum via a quick release coupling which can be electronically actuated from the flight deck in case of emergencys.
Not sure about a cutter, there's enough things in there to damage without adding anymore.
HTH
Dave I
"In Shallah"
