Duxford Diary 2020
Re: Duxford Diary 2020
Postby DCW on Fri 10 Jan 2020, 8:24 pm
Duxford Friday 10th January:
The wings of the CASA 2.111 departed this morning on the way to Kent:
Today's sunshine brought out several Spitfires, with PT462 flying and SM520 arriving:
Also around today:
DCW
Postby BMrider on Sat 11 Jan 2020, 11:03 am
A catch up on the ongoing Victor restoration in the conservation hangar, had a chat with Andrew in there and he tells me the paint is on order and we should soon see paint going on, it will be rolled on as was done in service apparently, the scheme chosen will be green / grey upper with white undersides, 55 Squadron
Home for the Victor will be undercover in the Air Space Hangar at the east end of Duxford which its self will undergo some reorganization at the same time
Some photos of it laid out like some huge model kit!
ImageVictor 3 by Mark Handley, on Flickr
ImageVictor 2 by Mark Handley, on Flickr
ImageVictor 1 by Mark Handley, on Flickr
I felt inclined to donate to this worthy restoration, here is a link if you would like to donate also;
https://www.iwm.org.uk/support-us/donat ... ctor-XH648
"Every little helps" :-)
BMrider
Postby Wyvernfan on Sat 11 Jan 2020, 5:29 pm
What was once a fly in the ointment to the IWM’s Collection will soon become the jewel in the crown, and rightly so.
I for one doubted that this would ever happen, fearing the worst as it slowly deteriorated outside, but I’m very happy to eat my words and instead heap praise on the IWM and its volunteers for carrying out such an in depth and much needed restoration on this unique survivor :clap:. I only hope I get to see it outside briefly before it disappears back inside for good.
Here’s hoping the Shackleton MR.3 follows the same route - eventually!
Rob
Westland Wyvern parts wanted; wyvernfan@gmail.com
Wyvernfan
Postby DOUGHNUT on Sun 12 Jan 2020, 9:41 am
Whilst understand it is IWM aircraft given its history very sad that an overall white scheme has not been chosen.
DOUGHNUT
Postby BobL on Sun 12 Jan 2020, 10:34 am
I was hoping for a anti-flash white scheme too - but as mentioned, just good to see such a deep restoration...
Underneath my gruff exterior is an even gruffer interior...
BobL
Postby DCW on Sun 12 Jan 2020, 4:46 pm
Duxford Sunday 12th January:
Very quiet today, with strong winds all day. Venturing out were a pair of PA-39 Twin Comanches, both early production models from 1970. A quick comparison suggests each has a different set of speed kit mods (rudder seals, fin strake, windscreen, cowlings). Looking good after 50 years, but I know which colour scheme I prefer !
DCW
Postby FlankerPhoto on Sun 12 Jan 2020, 9:11 pm
AirSpace will be closed all day Monday 27 January 2020 for a private event.
Heads up. :up:
FlankerPhoto
Postby cometguymk1 on Mon 13 Jan 2020, 8:50 am
The Victor has always looked so futuristic but the last photo really does look like something designed for space.
cometguymk1
Postby Stagger2 on Tue 14 Jan 2020, 4:02 pm
HuwJHopkins wrote:
rollason beta wrote:Hardly an over dramatisation of the Spitfire tip up. Sums it up pretty well. Power on throughout, state of disbelieve I imagine!
The difference between +7/+9 boost to +18 is vast in terms of warbird operation, though. There's no way the pilot was using anywhere near 'full power'. We're all better than Daily Mail sensationalisation like that! It might seem anal to pick up on it, but in this world where the truth seems to be less relevant by the day, you don't know who might read this forum and take that as fact.
Whoaaa! My Bad! Of course I should have stipulated "full Warbird Operator power +8 +/- Boost".... by way of not inferring "full Wartime BoB. power with +18 Boost" :oops:
However, from my own 19 images from throttle to roll-out spanning 3 seconds it clearly shows down elevator applied past the point where fuselage axis is horizontal & only becomes full up-elevator after the initial (inevitable?) prop-strike. Full up-elevator & applied take-off throttle are maintained throughout the sequence until after the prop eventually clears the ground & the aircraft aborts its t/o run. Only then is the elevator ever neutral for the roll-out, before closing the throttle & belatedly becoming up-elevator for taxying back to dispersal. I only see what I see! (which doesn't include 'Dead People') :wink:
The linked photo shows just how marginal this occurrence wasn't?? :whistle: :facepalm: This shot isn't mine. Full Credit to 'Brenden S'. It's borrowed from 'Airshow Photos'... "Your favourite image from 2019" posted below.
https://cdn.jetphotos.com/full/5/37011_1569651859.jpg
Stagger2
Postby Brenden S on Wed 15 Jan 2020, 11:32 am
It happened in front of me. The aircraft went to take off but aborted as the Spitfire next to it took off. Elevator was rested and then power applied. As the image speaks for itself the aircraft nosed over very quickly. All I can say is that it was quick reaction by the pilot which saved the aircraft from properly nosing over.
https://www.jetphotos.com/photo/9469256
Brenden S
Postby Chris Cussen on Thu 16 Jan 2020, 4:44 pm
Its easy to be an armchair critic.
Chris Cussen
Postby DCW on Sat 18 Jan 2020, 5:06 pm
Duxford Saturday 18th January:
Zlin Z.126 D-EYGL (built 1954) has been hangared for the last few weeks, but this morning was seen on a local flight:
Sharkmouth was also out for some exercise:
More sharks ( the Sale Sharks are a Rugby team, I believe ):
DCW
Postby Moggy C on Sun 19 Jan 2020, 10:39 am
I dropped into another forum where I am no longer welcome and found that the best thread of them all was no longer alive. It took me all of yesterday to find where it was hiding.
Thanks as ever for the work you put in, hopefully it won't be too long before a photo of XB appears here as a 'visitor'
Cheers guys.
Moggy
NOTE: How do I subscribe to this thread? There is mention of a link in the bottom left hand corner, but I am blowed if I can find it.
Moggy C
Postby Domvickery on Sun 19 Jan 2020, 11:49 am
Moggy C wrote:I dropped into another forum where I am no longer welcome and found that the best thread of them all was no longer alive. It took me all of yesterday to find where it was hiding.
Cheers guys.
Moggy
At the very bottom of this page, bottom left you have Board index, Subscribe or Bookmark topic
Domvickery
Postby Moggy C on Sun 19 Jan 2020, 12:26 pm
Got it.
Many thanks.
Moggy
Moggy C
Postby duxman on Sun 19 Jan 2020, 4:35 pm
Nice to see David and Mark Millers immaculate Dragon Rapide G-AGJG flying today in the nice winter sunshine. A far cry from her appearance when she first arrived at Duxford 45 years ago on the 17/8/75 !!!
ImageG-AGJG by AJCDuxman, on Flickr
ImageG-AGJG arrival at DX 17/8/75 by AJCDuxman, on Flickr
Duxman
Flickr -- https://www.flickr.com/photos/64209520@N05/albums
duxman
Postby Elliott Marsh on Mon 20 Jan 2020, 5:51 pm
Fantastic stuff, Tony! The decades-long documentation of Duxford's preservation scene (both IWM and private operators) by you and others posting here is one of the reasons this thread is so special.
Elliott Marsh
Postby DragonRapide on Thu 23 Jan 2020, 8:54 pm
Those images of 'GJG are tremendous!
I've heard horror stories of the state she was in on arrival. Thank goodness she made it in one piece! The transformation into what for me is still the finest Rapide around is an epic story of incredible dedication.
Looking elsewhere in the photos is fascinating too - the unrestored Control Tower, Sally B (recently arrived from Biggin, presumably) and no evidence of an air-side barrier!
Thanks for posting.
DragonRapide
Postby Hooligan on Fri 24 Jan 2020, 7:23 pm
I recall 'GJG parked by the Express Aviation ramp at Biggin Hill in June '75, looking incredibly tatty with a great rent in the rear fuselage fabric. And a horrid shade of purple. Next time I visited about 18 months later she'd gone and I assumed had been scrapped. When I heard she was being restored I assumed she'd been roaded out of Biggin. I think this is the first time I've heard she was flown out? Blimey...
Hooligan
Postby Davidmil on Fri 24 Jan 2020, 7:30 pm
Not only did she fly in, but the owner brought some of his family in it too! What could possibly have gone wrong?
Well, a heavily corroded main spar and a control cable down to its last two strands tell their own story. The flying wires were also well past their sell-by dates! But it all buffed out!
Davidmil
Postby DCW on Sun 26 Jan 2020, 5:39 pm
Duxford Sunday 26th January:
Things remain quiet at Duxford, activity is mostly covering routine winter maintenance. TFC's Corsair is one of many warbirds receiving attention:
DCW
Postby DCW on Mon 27 Jan 2020, 5:08 pm
Duxford Monday 27th January:
Spitfire HF.VIII 'MT928' (MV154) made her first flight this morning since the propstrike last September, and subsequent restoration to the UK register as G-BKMI. The dull weather didn't prevent a vigorous practice display on return.
The first Airshow items for the May Duxford Air Festival are now online at:
https://www.iwm.org.uk/airshows/Duxford ... flyinglist
And Legends tickets are now available.
DCW
Postby duxman on Mon 27 Jan 2020, 6:58 pm
A few more pictures of Spitfire MV154 in action today at Duxford
ImageG-BKMI / MV154 as MT928 by AJCDuxman, on Flickr
ImageG-BKMI MV154 by AJCDuxman, on Flickr
Duxman
duxman
Postby dazdaman on Mon 27 Jan 2020, 7:29 pm
Great news. There's something about that particular Spitfire that I really, really like.
dazdaman
Postby Rivet Joint on Mon 27 Jan 2020, 8:51 pm
Duxford Monday 27th January 2020.
As you can't have too much of a good thing, here's a couple more images of the Spitfire VIII from earlier today:
Spitfire VIII 'MT928' (MV154)/G-BKMI
ImageIMG_1885 by Fred Taylor, on Flickr
ImageIMG_1887 by Fred Taylor, on Flickr
Flickr - https://www.flickr.com/photos/85383837@N04/
Rivet Joint
PreviousNext
Users browsing this forum: No registered users and 8 guests
